In search OF lowering kit advice...
KidWgn
Certified Kid Hauler
St. Louis, MO
Changing springs is much more of a hassle than changing the knuckle. You also won’t be able to get anywhere near factory alignment specs with a drop spring, so you’ll have to do the offset upper control arm bushings.
completely false. I'm on a 4"F 5" rear drop, and just had to go back to a stock control arm bushing to get it out of positive camber. I'm on 2511s and coilovers, essentially making it a 2" suspension drop. A 2" drop does not require offset bushings.
@Roadrage I would do a 2" front spindle (2509 if memory serves), and a 4" rear drop spring. For a 4" rear drop, you'll need shock & control arm relocators to keep the geometry correct.
Here's some links, you'll need all 3, and I'd recommend adjustable control arms and trac-bar from APOC industries also.
Complete kit
Shock drops
LCA drops & endlinks
91RS
GA
A 2” drop spring absolutely does require control arm bushings, and they’ll tell you that. I’ve literally done it. Couldn’t get the truck past -1.8* of camber with a 2” drop spring. The 2” drop knuckle does not require control arm bushings and will align perfectly to factory specs.
R
Roadrage
Bremerton, WA
Thanks for the advice KidWgn, I think that will be my next step .... gonna start off small this time.
OK, so I ordered belltech 2" rear lowering springs and shock drop brackets.
I'm going to run this for a little bit and see how much lower I want to go.
I had a little setback the other day, On my way to work I drove over a manhole and my rear wheel went into the manhole.
After further inspection, I split the sidewall and busted the belts in 2 places.
I had to order a new tire and wheel, and I'm going to try to get the city to pay for it.
89Suburban
Bull in the china shop
SE PA
senseicraig
