CMoore711
:poker: ok, i think this deserves further explanation because simply adjusting the control arm sensors is not going to change the left/right height, that will only change how the shock reacts to a bump or it might affect how much psi is applied overall not left/right
I totally understand this, I think cmoore is leaving out some details in whatever he did, as adjusting the rod will not correct "lean" alone
I believe the lean is most noticeable in the front driver area so a extra 1/4" spacer in the front left would likely correct it for the most part
First off I know for a fact @Doubeleive and @Rocket Man are super familiar with our truck platform.
Also, I’m in agreement with the way the system works as you guys describe it.
My experience is with my ‘15 Yukon XL Denali when I lowered it…. Magnetic ride control and rear auto ride.
So stock that rear driver side was 37.5” ground to fender and rear passenger side was 37” ground to fender.
I lowered the vehicle 2/3” and installed the rear Belltech 3”-4” kit and used the 1” spacer. Driver side was then 34.625” and passenger rear was 34.25”. At this height both rear sensor rods were the same 3” length end-to-end. I then did the 10-24 machine screw as ride height sensor rod and extended the passenger side only by 1/8” so new ride height sensor rod was 3-1/8” end to end on passenger side only. The result was the both rear passenger and driver side landed at about 34.5” +/- 1/8”.
It would make sense if the shorter rod was “ignored”, but I swear this leveled out my rear. So that now the rear passenger where to driver ride height closer to being the same within 1/8” instead of being off 1/2” like factory.
Maybe the rear drop kit had more to do with it?
Well it’s not the air in the shocks that did it. It’s impossible. Side to side the air pressure is exactly equal, has to be with the air lines meeting at a T near the compressor. It was still probably settling after the drop. Here is a pic of the T. The white line goes to the compressor, the other ends are where the two lines from the shocks connect. You see, equal pressure to each shock. No way can one shock lift more than the other. The system in my bagged Silverado is fully capable of lifting each corner independently however. I plumbed it, I kinda know what I’m talking about. image.jpgimage.jpgimage.jpg
Grady_Wilson
Wyoming
Swapped out one upper control arm, but had to leave the other for tomorrow, because date night.
Also have the tie rods to replace, but I'll schedule an alignment before either commit to doing those.
Great job, if I'm going in that deep, I am replacing the axle while I'm in there.
No way I would want to do that again, any time soon.
The airlift stuff seems to be decent, the Silverado isn't lowered anymore but I changed the bags for a lift instead of a drop, it could be used with a tank and manifold but would take a different system to have it control each wheel, still handy when needed
Sir_Hiro
Well it’s not the air in the shocks that did it. It’s impossible. Side to side the air pressure is exactly equal, has to be with the air lines meeting at a T near the compressor. It was still probably settling after the drop. Here is a pic of the T. The white line goes to the compressor, the other ends are where the two lines from the shocks connect. You see, equal pressure to each shock. No way can one shock lift more than the other. The system in my bagged Silverado is fully capable of lifting each corner independently however. I plumbed it, I kinda know what I’m talking about. View attachment 453646
I see gap between door and ground. You need to Channel the body. :D
Charlie207
LFOD, New Hampshire
The volume on this unit was VERY loud. Radio reception was good compared to the last one I tried. I didn't like the setup of the operating system of the wireless carplay. You could not switch from Spotify to Radio and back it would start to cut out and act stupid. The google maps and directions looked very nice.
There was a Amazon review that said you had to unlock the headunit setting (with code 000000) and turn down the source volume from 100 to 50, and then it would be more balanced with the vehicle volume.
Charlie207
LFOD, New Hampshire
Fun times! disconnecting the sway bar should make it easier
I was going for lazy, and didn't even need to remove the strut, even though I removed all the nuts/bolts. Soaking everything in PB Blaster for a few days prior was probably a good idea. You just hold the camber plates against the frame, and tap the bolts out. Luckily mine weren't rusted/fused together.
If you lift both front wheels off the ground you can leave the end-links connected. I had a short prybar, and that was enough to manipulate everything back together.
Excelelecrtric
