2015 Tahoe: constant 12v source.
ReaperHWK
I installed a dash cam in my 2015 Tahoe LTZ and hard wired it using a kit that allows for parking monitoring. I ran the wires to the driver side fuse panel and it was easy to find a switched 12v for the camera but for the life of me I can’t find a constant 12v source in that fuse panel? I need that for the parking monitor function.
Anyone can help?
PPV_2018
Senior Member
U.S.A.
I could but I have the wires already routed to the fuse panel I showed. Would love to find something with constant 12v there if possible.
No I was saying that the fuses for the cigarette lighter or usb should be 12v constant i would think. Not certain.. was just throwing out ideas
And i cannot verify at the moment or i would check
Q101ATFD
Not sure which dashcam you're using, but I ended up getting the Garmin Constant Power Cable. It plugs into your ODB port and lets you select how much time it supplies power to the USB output ports. Super low profile, you don't even notice it's there - I was going to do hardwire like you until I came across this.
tkwatts
