2001 GMC Yukon XL (Aka Beast)
Bigburb3500
I decided to check upon my dot 3. It smells like bog. I don't know how to bleed brakes. So I used a syphon, and added new Prestone dot 3 max. Filled reservoir till max. And then started vehicle and pumped brakes few times. This is cool in reservoir after I changed it. Probably I will do a procedure few times and then go to repair shop for new pads and properly bleed them. And flush brake fluid again. I just want to do what our shop will not do. They never washed brake lines, they never wash engine. So I will buy some 5w30 pensoiol and wix filter. And do procedure again. Just waiting for abs module to show up. I decided not to take it apart , and go and order the cheapest one from Rock Auto.
Definitely time to do brake fluid! Brake pads are super easy on this truck but if they haven’t been done in a while the salt might make the job a bit difficult.
Super Moderator
Elev 5,280
No harm, just advantages, in using DOT 4 instead of DOT 3. It has better qualities, so consider having them use DOT 4 when flushing the brakes.
makintoshnex
makintoshnex
What about mixing dot 3 and dot 4? Will it go bad? I saw in AutoZone some universal dot 3 and dot 4 in one bottle. What is the difference between?
Super Moderator
Elev 5,280
It can mix with no problem. What they sell in the DOT 3/4 bottles is DOT 4, backward compatible with DOT 3. It's best to do a full flush to get the full benefit of DOT 4 (primarily the boiling point) but either way works.
If interested, a little reading here for comparison specs: https://www.autozone.com/diy/brakes/dot-3-vs-dot-4-brake-fluid
makintoshnex
makintoshnex
I
Go for it! Here’s a video for it! I’m all about a DIY repair. Especially if it gets the light to turn off for a short while you at least know the root cause.
Can't get to a module. My truck is missing jack. So I decided to go with hydraulic for 6000 lbs. Eventually I barely managed to fit it. And in a wrong place. When jacking up, I bend a frame. I'm not the best mechanic, and I think I may do more harm then good.
Bigburb3500
I
Can't get to a module. My truck is missing jack. So I decided to go with hydraulic for 6000 lbs. Eventually I barely managed to fit it. And in a wrong place. When jacking up, I bend a frame. I'm not the best mechanic, and I think I may do more harm than good.
Uh-oh… Am I understanding that you bend the frame while lifting it with a hydraulic jack?
This should not need a jack as I used a packing lot and drove the front two wheels on a curb then slid underneath. The module is on the frame rail, not sure if you even need to lift the truck.
makintoshnex
makintoshnex
It's not that much. But still I'm afraid that I might have damaged something that is inside of it, maybe some lines etc. this is my Jack.
makintoshnex
makintoshnex
Some shuck from eBay sold me wrong harness. Instead of passenger he sold me driver side. Now I have to repin the whole thing
makintoshnex
makintoshnex
Looks like my manipulations didn't brought any success. It made it worse. Brake light came back. GMC burned brake light switch again. I'm starting to hate this vehicle. Everything should be simple on these rings. One 2 three and done. I should not be dying under it.
Bigburb3500
Ok.
1) DONT GIVE UP!!!! This is just a setback. You have a freaking awesome truck!!!!!
2) The lights are probably because of the brake module but the rear light might be because of a short? I have not had that problem before but I hope, and believe, someone on here will be able to help diagnose it.
Almo7annad
