Need Help/Advice on Dealership Repair Work
ldm882
I have a 2015 Tahoe LT. So far I've had 4 cylinders, the transmission, and the spark plugs/wiring replaced at a cost of over $10,000. Now the dealership is telling me the catalytic converter needs to be replaced. I feel like the dealership is not being upfront with me , is not catching things it should have, etc., but I don't know enough to argue otherwise. And I very well could be wrong (again, don't know enough.) That is why I want to document what has occurred so far, what the dealership has told me and the repair work it has performed, and ask that any of you with knowledge please advise me. A couple of things:
(1) As I have stated: I don't know anything about automobile mechanics. I am admitting that up front. I am posting what has happened so far in order to get advice and help me determine if the dealership is doing all it should, if I need to ask specific questions, etc. Please don't criticize me for not having done something, for having done it the wrong way, etc. I am asking these questions because I know enough to know that it feels like the dealership is taking advantage of me. Again, I admit that. Generally, other Tahoe owners have been very helpful when I've asked for advice, but if you're just going to say I'm an idiot, etc....I understand that is your opinion, and you're more than entitled to it, but please only respond if you're actually trying to offer advice. Feel free to remark to yourself that I'm an idiot, but this has caused me a ton of stress and money, and I'm just asking that you be a decent person.
(2) Somewhat related to the above - I did not want to take my vehicle to the dealership. I have a friend who owns and runs a corporate body shop and he almost always does most of the repair work on my vehicles, but because of the extent of the work and his shop not doing transmission work, he told me I would need to take it to the dealership. I know a lot of you don't like dealerships - and again, I never take my vehicles to the dealership either. But in this circumstance I didn't have another choice.
I will try to keep this summary as brief as possible while including relevant information. Here it is:
- In December 2024, the vehicle began shaking while driving, multiple instrument lights came on, a gas smell was in the cabin, etc. I took it to my friend, he advised that because diagnostic code P0300 and P0308 were popping up, I probably needed to have Cylinder 8 and other cylinders replaced, and that I needed to take it to the dealership because he didn't have the shop space to take apart the engine. The dealership confirmed his diagnosis regarding Cylinder 8. They also advised that the transmission was slipping and needed to be replaced. Specifically, here is what the dealership said per the invoice:
"Diagnostic codes P0300 engine misfire detected and P0308 Cylinder 8 misfire detected. Transmission is slipping and fluid pump is whining. Perform compression test and fuel injector balance test. Found injector for Cylinder 8 is bad. Recommended replacement of all 4 injectors on Bank 2. Customer just wanted to replace the one that tested bad replaced one injector and reinstalled all components, re-ran fuel injector balance test with another injector testing bad. Removed all necessary components and replace the 3 remaining injectors on Bank 2. Reinstalled all removed components and re-ran the fuel injector balance test. All injectors are working as designed at this time."
So, for this initial repair, the dealership replaced all 4 cylinders on Bank 2 and performed associated work at a cost of $3,000. The dealership also replaced the transmission at a cost of $6,800. I got the vehicle back on March 7, 2025.
On March 24, 2025, while driving, the check engine light began flashing and the traction control light also came on. The vehicle was also shaking, especially while idling. I googled these symptoms and saw how bad it is when the check engine light is flashing instead of being solid. I called the dealership and told them about the engine light flashing and they referred to it as the death light or something like that. I had it towed to the dealership the next day.
On April 3, 2025, the dealership told me that the park plugs and wires need to be replaced. They specifically told me, "With it being multiple misfires and plug and wire issues, that is more than likely the issue." I tell them to replace the spark plugs and wiring. They do so at a cost of $821.66. The dealership also tells me, "Truck is ready. Your gonna need a catalytic converter or go get it cut off soon. The only code that came back was for being too rich and it is bogging down some. I would just get it cut off at a muffler shop when it gets to that point."
On April 4, 2025, I picked up the Tahoe. I immediately notice that check engine light is still flashing, the traction control light is still coming on, and the vehicle is still shaking while idling. I tell the dealership. They tell me, "Gotta be the converter. Go get it cut off."
The paperwork the dealership gave me for the spark plug/wiring repair states: "Replaced spark plugs and wires as starting place due to spark plugs being fouled out. Test drove vehicle and check engine light returned with a fuel trim code and misfire code. Live data showed all cylinders on Bank 2 with misfires and rich fuel mixture. Recommended replace catalytic converters due to blockage in exhaust flow on Bank 2 causing fuel trim reading to be rich."
So that is where I'm at so far: I've replaced all 4 cylinders on Bank 2, the transmission, and the spark plugs/wiring. The vehicle still has a check engine light that is flashing, and the dealership is now telling me to replace the catalytic converter or have it cut off and replaced.
The dealership has offered to let me speak to the mechanic, but I don't know what questions to ask. Any advice/thoughts are very much appreciated. And if you need any more details or have any other questions I will do my best to answer. To date my repair costs are $10,706.21.
Maxentropy
My '14 Yukon XL SLT 5.3 has 194k on the clock and has had a similarly expensive year in the shop. Transmission/TC, rear main seal, thermostat, plugs/wires, control arms/ball joints, coil pack (#4), oil pressure sensor. So I'm also in for over $10k in a year. I don't think your dealer is at fault ... it just gets expensive at a certain point in the lives of these trucks. Blame GM's transmission if you need to assess blame, but everything else sounds like "shit happens" to a 10 year old vehicle.
some questions to ask the "mechanic"
1. was a backpressure test performed? and if so what was the PSI reading?
2. is my VIN under the special coverage for the injectors that were already replaced? (some of these vehicles have a 10 year special coverage for injectors failures)
3. it was suggested by the service counter that the CAT/CAT's be cut off, wouldn't that also cause a check engine light????
not questions for the mechanic.
None of the above sounds like anything incestuous has been done by the dealer, there may have perhaps been some "guessing" involved, it happens.
you did not provide any mileage info, but it is possible the cat/cats could be clogged, providing the backpressure test reflects that (max PSI is around 2.5 at idle)
if the cat/s need to be replaced it would be wiser to just have a muffler shop weld on aftermarket replacements, you do not indicate where you live so laws vary from state to state if all you need is federal cats you can get away with some cheap and not have a check engine light.
a new factory Y pipe is not exactly cheap, probably around $1400+ last time I checked (depending on where it is purchased) a dealer may be asking twice that or more.
so aftermarket is going to be cheaper in almost any case.
if the backpressure test shows it passed, then next up would be a intake service, the motor you have is direct injected and they are prone to getting carbon build up inside the engine and that alone can cause the misfires/shacking/lack of power, etc
you might want to do the intake service regardless depending on the mileage.
***also for whatever it worth, there is nothing wrong with asking for help/advice/educating yourself about the vehicle, places like Facebook and most social media is not the best place to ask as it full of fools, quite literally. Those type of people kind of self-eradicate themselves around here. Thankfully most of them do not even have enough brains to make it on here to begin with.
ReaperHWK
In all honesty and without judgement if you can’t diagnose and repair a vehicle yourself you shouldn’t own one that is 10 years old because going to shops will bankrupt you.
You’d be better off leasing or getting new/newer vehicle and getting the extended warranty. Just my $0.02.
Hope you get this all fixed but from my quick read it all looked like misfires due to plugs and injectors. If the cats were the root cause of fouling them maybe but you’d need a scanner with mode 2 to diagnose for the misfire counters and which cylinders it’s in. Also there are methods to diagnose a cat using the o2 sensors and some test routines. Good luck.
Coveman
I worked at a GM dealership years ago, they hire off the street and turnover can be an issue (that hourly labor rate they post in the service area is NOT what the mechanic makes, that’s dealer money); nowadays I dont think any dealership has all the fully qualified mechanics they want that can work on the new vehicles. As customers we mostly deal with the service managers who “handle” both us and the mechanics…but often instead of getting to the bottom of things they smoke and mirror us and send us down the road (they hope!)
Do a google and yelp search of your area and find some highly rated independent mechanics. Ask them how much to replace your plugs and wires, and how much a new fuel injector runs since you already know what the dealer charges. Then when you find someone you’re comfortable with ask about the catalyst. Most independents are comfortable with aftermarket catalytic converters that cost a couple hundred rather than oem that are well over a thousand dollars. That’s part of why your charges were so high since dealers use marked up OEM parts.
a simple backpressure test will tell you if a cat is clogged or not, no computer or anything needed, gauge, hose, fitting.
PPV_2018
U.S.A.
Let me get this straight.. the dealer told you that you needed to go and get the cats cut off… It’s interesting how everyone is glossing over the fact that this dealership has advised their customer to do something illegal .. even if your state doesn’t smog test it’s still illegal to straight pipe it..
And even still “cutting off” cats would not “fix” a dammed thing.. and you would still have a check engine light, guaranteed.
Also, you state that in the dealer notes they say the transmission was slipping and needed to be replaced.. but you did not indicate that you were having problems with transmission initially.. so, you went in for some misfire codes and ended up with a bill for 4 cylinders, spark plugs, wires, and a new transmission..
I would find another mechanic.
are you a GM corporate officer or something, because I’m sure the suits at GM and every other automaker would love if every non-car person followed this philosophy..
Learn to fix it or find an *honest* mechanic would be better advice.
ReaperHWK
Nope just common sense. An “honest” mechanic would charge you $150 an hour so get the warranty. If this guy had an extended warranty or a lease he wouldn’t be bent over a log right now.
There is no “honest” mechanic. They all want to make $$ and will take advantage of anyone that doesn’t know up from down.
My mother in law has an older Honda. She goes to her trusted mechanic and they tell her it’s going to be $1500 to change her spark plugs. Dealer was higher. I did it for $200. Jist because you have to pull the intake manifold they jack the labor to the moon. ALL mechanics will do this.
PPV_2018
U.S.A.
except that is is not common sense, it’s cynicism
Using your philosophy, a vehicle owner would be spared the rod on mechanic expenses but then “bent over the log” from the finance company AND the insurance company….
Fact is, Vehicle ownership is costly, regardless if your car is new/old, domestic/import, and regardless if you are ASE Certified with 7 patches on your shirt, DIY car guru, or someone who’s never turned a wrench in life. It costs you one way or another. just because a mechanic charges for labor and parts doesn’t mean they are not honest, or are ripping you off; and there are honest mechanics out there…
.. that being said, the reason why i work on my own vehicles is because I do not trust mechanics.. lol so yeah — but this is also in part because i grew up with old vehicles that needed repair and had to learn to do it myself because $
At this point in life it’s not even about the money, I prefer to do my own repairs to know it gets done right.
I do, however, agree about getting an extended warranty from a reputable company in the case of not knowing about car repair.
ReaperHWK
Yeah I get that and see where you’re coming from. But for a person who gets sold a transmission when it’s probably just misfires and doesn’t have the knowledge to question and direct the work by a mechanic. I would have said do the plugs, coils, injectors and said don’t touch the tranny until after that work is done. Etc etc.
If they had a warranty the dealer would eat all that and wouldn’t be doing stupid crap, well they probably still would but the customer wouldn’t be paying GM would.
Mike4400
