ESV roof rack...What should I expect...
KMeloney
You can't use the hardware from the stock Burb rack on the ESV rack for mounting it?
Yes, you can -- and have to. BUT, there is a plastic "nut" (more like a spacer with a flange) that gets mounted on the roof first (via the stock bolt, and in the stock hole) as part of the Esky/Denali rail mounting. This nut secures the roof rail in place. Without it, the center of the rail would have play in it and would be not be secure. With the longer ESV rails, you might even have two of these per side.
They are $2 parts, but they're absolutely necessary. Just want you to be aware of this if you weren't already.
Administrator
Great info! Thanks KMel. I would not have known any of that so thanks for giving me a heads up when the time does come :waytogo:
THE YETI
Director of Operations
South FL
Yea that is a good deal!! I'll keep an eye out for you Jacob! I've been on the hunt for some esky/denali running boards too. Real hard to find a nice set for a good price. These two mods are gonna look great on your burb!!
Jacob already passed up a $200 roof rack... :nono:
Not sure if they are absolutely necessary. We installed my wife's ESV rack without using the center pieces and it holds secure just fine, doesn't budge, doesn't shimmy, and holds up at 90mph just fine, lol.
We will get those center nuts tho, but just by utilizing the two stock bolts on the front and back of the burban pieces, it holds.
KMeloney
Let me clarify. Your rack will be secured to the roof without these nuts such that it's not going to blow off the roof or anything like that. But, if you actually use the rack to mount something on the roof, or you use if to pull yourself up on the tire or running boards when, say, washing the roof, it will flex there.
The way the nuts work is like this: there's an eye-shaped opening on the bottom of the rails at the center, and the rail is set down onto the roof over top of this nut. Then, with the rail set down, the rail is slid backward (or forward -- don't remember which) so that the flange on the nut locks the bottom of the rail into place (picture sliding the claw of a hammer under the head of a nail). The center of the rail is now held securely -- and then you bolt down the ends of the rail where the end caps go.
Without this nut, there's no way to secure the center of the rails. There's no access at the center of the rails to the mounting screw(s) like there is before the end caps go on. I think that this center nut IS absolutely necessary.
Administrator
^^^and this is another reason I made this thread. There's always something you don't think about when buying stuff like this :)
THE YETI
South FL
:slap: I did not "pass" on it. Timing was wrong due to circumstances out of my control :deal:
blah blah blah! :sleepy10:
:chicken:
i will agree with that, i see the concern. if you plan on putting stuff on the roof, it would be nice to have the nut. But I did pull my 200lb ass up by holding the rack and it stood stoic. It didn't budge or flex. But we just put it there for looks, not really to serve a purpose other than that. I don't think I've put anything on the roof in the 3yrs we've had her.
EDIT: I do remember a christmas tree at one point!!
Administrator
I actually refuse to travel with stuff on the roof. I don't need that headache as I'm travelling at 80 mph down the highway. With my luck it'd fly off and our crap would be all over the highway as people drive over it!! :D But I do pull up on it when I wash the roof.....
felixgun
Lafayette, LA
LOL in my book that's passing it up. Unfortunately other things come first huh Jacob? I feel you though.. I had to pass on some esky running boards brand new a few months ago and highly regret it!!!
Administrator
Yeah, I'll have a hard time beating that deal so I'm sure I will kick myself. I guess I could have just suffered with 97 degree heat in my house with no AC while an Esky roof rack arrives at the house and the wife and kids suffer from heat exhaustion but I'm thinkin' that might not have gone over too well :lol:
Ain't life grand :D
Timqua
