Got my new plugs today......
taylorjm
Saginaw, MI
Are they the super duper low temp plugs that are guaranteed to make your a/c run 10 degrees cooler?? :Big Laugh:
S
Stresst
Oh my god not you too! Is there anyone on this site that is not effed up?? LMAO
taylorjm
Saginaw, MI
If I was you, I would also be worried about all those electric fans and clutch driven fans you have on the front. If you get a good tailwind, you might just go airborne with all those propellers going!
S
Stresst
Im hoping for a good tailwind so I can open the rear glass and finally get a cool breeze to blow through! LMAO
99Yuk
Northern Ontario, Canada
But wait! It gets better yet!
MSD recommends .40 for the 350. AND they recommend a colder type plug.. WTH is a colder plug?
How does a guy buy AC Delco plugs that are colder?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If you are going the full msd setup then run autolite 605 copper core plugs(not platinum) at .060 tops. A colder plug is one that dissapates heat faster because there is more ceramic insulator material in contact with the outer metal shell. Each manufacture has it own numbering system for specifying heat ranges. If you run into detonation problems go colder if you get fouling problems go hotter plug Tip temperature can change about 100 degrees in either direction hot or cold.
AtomicHoe094
Atomichoe094
cleveland, OH
very nice Sun. I just did my plugs at gapped them to .50 i believe. Used a colder plug from ACdelco and im running msd coil, msd6a box, msd cap,rotor, and wires. Runs a lot smoother but havent driven driven the hoe yet from this drop.
Zues
