Illuminated cup holders Tahoe (How-to)
Anthony
2004 Tahoe LT (MA)
Westen MA
Hey guys,
Wondering if any of you did this so far?
02TahoeMD has done this and it is pretty cool looking
Pics:
________________________________________________________________
Heres the Directions: (Thanks 02TahoeMD) :Handshake:
Time: 90ish minutes
Well, this forum just keeps planting ideas in my head, and I tackled the latest idea today. I added LED lights to the cupholders on my Tahoe, it is a very easy mod to do, and I am happy with the results. Wanna do it yourself? Read on.....
You will need some 12V LEDs. I had some I had gotten from eBay awhile back just laying around, and used them. They are super convenient to use with their long leads. I got mine in red:
Next, yank out your cupholder and grab a drill bit that matches the size of the LEDs. I used a bit that was just a touch smaller than the bulb, and worked it around after drilling the hole to widen it just a tiny bit. I only used 4 LEDs for the entire project, since I wanted a subtle light, not too overpowering. I put one one each cupholder and one at each end of the catchall portion of the box.
After drilling in the holes, touch a dab of an adhesive to keep them in place. I used a touch of JB Weld on mine. I then routed the wires and connected them together, and then attached them to a quick disconnect plug that I had gotten from Pep Boys.
I have a 12V switched source that I routed into my console to have as a "master on" for my GPS and XM radio. I just used this as my power source and spliced in the other side of the connector. Voila! Now I have lights. Of course, you could also splice into the dash lights, or tap a line from the fuse box to do this if you want, anything 12V will work fine.
To help cut down on some of the glare directed back at the driver, I painted the tops of the LED bulbs flat black. You can kind of see the bulb tops in this photo:
Last, I took a couple of photos at night with no other interior or dash lights on to show the effect that was achieved with just 4 lights. A water bottle helps to add to the overall glow that you see.
tast101
Colton, CA
I'd assume just like you hook up any other LEDs, run them to a switch, drill a little hole, put the LED there, use some hot glue or something to hold it there on the backside.
jdixon74
Tennessee
Sorry to dig up an older thread but has anyone done this in blue? I was thinking of playing LED's in all the pockets in the dash also..
1fatho
Alaska
Do it, take pics. Wiring isnt LED color specific. Im going to do my cluster, all interiors, cups, and Phys' footwell/back seat mod all in green when this semester is over.
ASK if you need help, but look first......
EDIT* and check out the sticky about for interior and exterior LED replacement. Check the last page of the thread too because I just ordered and I found a coupon code online that gave me like 10% off or something.
Rink
