Overdrive doesn't work when warm
Red kappa
Ok I'm new on here but I just bought a 1998 Tahoe with the 5.7 and 4x4 well when it is cold the transmission shifts great but when the fluid warms up only 1st and 2nd gear work. If you have it in o/d and it goes to shift into 3rd it just revs up like it is in natural but you put it down in 3 and it comes back but is still running in 2nd any help would be great thanks
R
Red kappa
I know I just got off of the phone with a buddy of mine and he was thinking many the 3rd and 4th gear silanoid
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if, it is the 3-4 clutch the transmission needs to be dismantled and an overhaul is in order as you already would have it in pieces. this is assuming the clutch material is wasted.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
R
Red kappa
But if it was the valve body wouldn't it have problems hot or cold?
SunlitComet
OBS Jedi-Do Good
not necessary.
As a tranny gets hot the viscosity of fluid changes a tad bit and clearances can have minor changes that can effect components. those changes can also effect whether or not a cracked apply piston for the clutch is doing the damage.
Timqua
