03 escalade air ride question
M
Mbz03
If your lifting it they are.
If your keeping stock height then no go with the 4600hd. Its the same shock, just the 5100's are longer. There is no quality difference.
Not lifting I just bought a part number
24-186643 would those work for stock height maybe lower it later on 2/3"?
M
Mbz03
can I used the 5100 since I already bought fronts
TheAutumnWind
They are usually listed as "for 0-2" lift" So it should work. But if you plan to lower it at all I definitely would not use those.
M
Mbz03
Thank you so much for the help my air shocks are blown so trying to get some shocks for now, I like to drop it but the roads suck in New England lol
TheAutumnWind
No problem. I love my bilsteins.
Sent from my HTCONE using Tapatalk
TheAutumnWind
that's good to know do I have to get new rear springs would u recommend them and what brand my escalade has 154k on it
I am still running the factory 180k mile original springs. If you tow, or your rear end sags you can get moog z71 springs to stiffen up the rear. Usually this lifts the rear about 1/2"
Personally I'd suggest getting the shocks installed first and then deciding if you think you need new springs. The shocks will make the rear feel much more planted and controlled than before.
M
Mbz03
ur so awesome I'll get the yellow bilsteins u send me the link off I think they wore 4600 series part number 24-065009 and 24-185677
Ispa805
