2003-2006 Rear HVAC/Radio Control Backlighting?
Xcaliber1028
Is the rear HVAC or Radio control panel backlit?
The one in the back of the center console on the floor of 2003-2006 tahoe, suburban, silverado, and avalanche.
I took mine apart, it has bulbs, they are not burnt out (i confirmed by measuring continuity across the bulbs). But they do not light up. However the bulb bases look slightly melted as if they did work in the past.
Can anyone confirm that their backlighting is working? Maybe post a picture? It would be greatly appreciated.
New to the forum btw, joined because I can't find information on this anywhere.
Mr. 960
they work. Try giving the upper back portion of the console a smack and see if they come back on intermittently.
Grind
Damn. I just noticed that mine aren't working, either. Discovered it when I was trying to figure out if my rear heat was working (it's not).
mountie
"What'sa behind me doesn't matter "...... ( as he breaks off rear view mirror - Movie, "Cannonball Run" - 1981 )
Huh..... I should sit behind to see if the lights work ( never sat there when ignition key on)
HiHoeSilver
Away!
Chicago
Don't do it. You'll end up like the rest of us in here with another thing to fix!
rnfernandez1968
