1badc4
- Joined
- Jun 17, 2019
- Posts
- 282
- Reaction score
- 216
Looking for some help with transfer case wiring 2001 Tahoe 246 transfer case I swapped the transfer case and apparently got a couple wires crossed because I instantly got abs lights transmission won't shift out of second gear there for plugs that all have the same end obviously I have a couple crossed not sure how many the only thing I could find was a diagram but did not have color coding so I could only go by length of wire pulled all the plugs back off try to determine wire colors at least two of the plugs have the same color wires can somebody help me how to verify what plug goes where the diagram online doesn't help because it doesn't show the colors of the wire thank you
