steve671
I am posting this because I saw in another thread which I can't find now, someone trying different 6" door speakers to get better midbass. If you want to get good midbass from your 07-14, put 8" midbass or woofers in the doors. I did this in my 08 Sierra with the use of a speaker rings/adaptor that I designed. I have attached a PDF with a scan of a speaker ring/adaptor. You can print it, and cut it out and use as a template to make your own out of 3/4" MDF.
This along with a good amount of sound deadening, and foam between the speaker and the door panel, will get you good midbass in one of these vehicles.
