Border Patrol bumper mod
emann_01
it could be a flood light for scanning a field while they are patrolling...so they have a very wide beam pattern...?? maybe, just a guess
stevek
Dallas, TX
That bumper is cut right on a factory body line, I think it looks tough add a straight 1.5-1.75" tube lightbar with 3 or 4 lights and it would look even better. I should have never looked at this thread, now the gears are turning in my head...
No moldings either. Looks lifted about 3 inches, but it might just be an illusion
2 E L O
Omaha, NE
Hmmm, I think it's just leveled. It looks like stock height in the rear and like the front is up 2-2.5".
Those are stock 17" wheels with probably the stock sized tires (265/70-17) which are only about 31.6" diameter.
Here's a picture of my Tahoe with 31.6" diameter tires and a 2.5"/1" leveling kit. Mine looks like it has about the same tire/fender gap in front and slightly more or about the same tire/fender gap in rear than the BP Tahoe.
drastevenson
Does someone know who / how the Border Patrol mods the front bumpers on their 2007+ Tahoe's?
It appears that they have a mondo prerunner style skid plate as well.
Thanks!
Did you ever find a skid plate / bumper styled like that?
Ilikemtb999
Denver
This thread is very old but I used to own a BP Tahoe with this style skid plate.
Here are some pics I have. Might have more. It went from the backside of the bumper support to the frame underneath and had aluminum plate screwed to that.
It also had a strap to keep the hood open a few inches with crazy stiff hood struts, had a 2” lift block up front and 2” lift springs out back from a company called Baja designs (I think, I have the springs still I can look if someone cares). They were in Cali and did up fitting for BP
Marky Dissod
Some threads age like Susanna Hoffs.
Is there a GMT800 version?
Or do I just start by removing my front bumper and going from there?
RooTBeeRthe1st
Yeah, the bumper cut is easy. Just follow the body line. BP follow the notch up in the center which is why you see the black metal bumper in the middle.
I cut mine straight across instead so it's only plastic visible still.
The skid plate I'm not sure.
kjetilaf
