cjmcglaughlin
Hey all,
I need advice for the specific situation I’m in. This might be a bit long so I apologize for that.
I have a 2005 Tahoe with a 4.8 and 162k. I’ve had the truck for about 3 years but it was my mom’s before that since about 08. Anyway, before I owned it (around 2017 and about 120k) there was a problem with coolant in the oil and combustion chamber that my dad (a Honda mechanic) attributed to the Castech head issue. He was planning to sell the truck at that time so he used some sort of stop leak, which has held to this day.
I’m planning on pulling the motor to replace a RMS (don’t have access to a lift) and do a few other odds and ends and wanted to put a permanent fix on this issue. After looking I see my heads are 862s, and I pulled a valve cover and couldn’t find the Castech logo anywhere on the head. Upper valve train was pretty clean too. Based on the fact that I can’t see the Castech logo, I’m thinking these are non Castech heads. I’ve read about a lot of Castech head issues and have also never heard of that leading to coolant in the combustion chamber, just the oil. Both of these lead me to think it was likely a head gasket failure instead of a head, but I’m not sure.
While the engine is out I’d like to replace the head gaskets & intake gasket, as well as the RMS. My dad suggests though that at this point if I’m putting on head gaskets I should get the motor rebuilt. The truck runs great and doesn’t use much oil at all. I’m unsure.
Appreciate if you read all that. Any advice is appreciated. Does this sound like the Castech issue? What would you all do in this situation?
Thanks,
Cody
Thanks,
Cody
