EddieC
- Joined
- Aug 9, 2014
- Posts
- 634
- Reaction score
- 499
2008 Tahoe;
Today our air conditioner blew nothing but hot air even though the hvac display light was on.
We've never had an issue with it before and it generally blows icy cold, at least in the last memory of serious,y using it. I say seriously because we are just coming into the season but the auto settings turn the ac on frequently. It has never needed attention in the past.
I checked three fuses and swapped out one relay, all which appeared ok, then upon closer inspection I found the compressor clutch engaging for only 3 seconds and then running 12 seconds disengaged, then repeat and repeat when the ac was turned on.
I ran out for a recharge kit and on the initial test the gage showed needing a charge. Using a 20 oz can it took most of the refrigerant but did get in the green zone on the gage near the minimum acceptable pressure of 30 psi.
Once the charge was started to be applied the compressor clutch would stay engaged as it should.
Now the air from the ac vents is cool, not cold. Took it out for a ride and it seemed a bit cooler, but again not cold as I remember. There was a definite difference between ac off and ac on though.
Fingers crossed that it holds the charge in the coming days. I am not understanding why it doesn't seem as cold as it seems to have been all (?) of it's previous long life.
Any input would be appreciated from those who have been through it or are familiar with the system.
