If you need to replace fasteners, here is the info:
Both front and rear panels have 6 of the white fasteners #11519031 and 4 blacks. I don't know what the part # is for the black ones.
The stealership near me was a no-no on this part. They wanted $10.32 for each one.
If you are replacing the smaller fasteners #11519031, that is pictured on the left. You can see the difference.
If using ebay or amazon make sure the size matches, using the part # alone does not mean you will get the fastener on the left. I searched for #11519031, ordered what I thought was #11519031 as it stated that # on the listing. And the fastener on the right is what showed up and it doesn't fit.
It's very common for the white fastener plastic holder to break and you won't actually see the 6th fastener (labeled)
