BattleTank
Senior Member
- Joined
- May 16, 2024
- Posts
- 118
- Reaction score
- 160
Have we gotten codes out of it yet?
Only codes are fuel pump system & EVAP related, see above for the fuel pump & the EVAP is a sticky vent valve.Have we gotten codes out of it yet?
Found it!!!
The ABS module was cactus. The fuel pump control module connects to the ECU through it.
What's the spread on the ABS module being out causing the vehicle not to crank?
(Background: the start relay only fires when the ECU is commanded to by a diagnostic test, it will not fire the relay when the key is cycled, and it does properly report the key's status.
Thanks, but it's not lights going crazy, it's the ECU not allowing the vehicle to crank. It registers the key turning to Start, and will fire the starter only when commanded to by a scan tool..When i had lights going crazy, it was a ground.
I even had the truck stall once after a long drive home with both the front and rear ac on full blast.
Hours before that i drove through a mud puddle.
I found the mud coated the grounds on the driver side under the driver seat, and the rear seat.
I cleaned everything, and then removed the grounds to inspect.
They looked great, so i cut the wire insulation back.
I found green corrosion!
I cleaned that up with electrical contact spray and soldering flux, then flowed solder into the joint.
All has been great since then.
