2017 Tahoe PPV - Wiring up a full center console
ryansclzo
My 2017 tahoe ppv came with no center console, so I bought a second hand one. Is there a wiring diagram available anywhere to be able to at least hook up the USB and 120V outlets? There's also heated seat buttons on it but I'm not sure if I will be able to hook up aftermarket warmers with it. Ideally there would also be a way to get rear climate control working but that may be too much work.
Any insight would be appreciated.
Trey Hardy
Eastern North Carolina
I know in the older body styles the wiring harness would already have the plugs setup and hid under the carpet if that’s the case it would be plug and play but I don’t know much on the newer ppvs
So like in my 07 work truck the harness for the heated seats and what not were already setup but I would have to swap from a wt door panel harness to a Ltz style with the heated seat and power window switch’s
LetsGetShwifftyy
Maryland
I just got a 2017 PPV, did you ever get to hook up the center console?
tritron
There are wiring harnesses on ebay for 2015- 1017 but what about 18 - 20 ?
fondupot
