2018 Denali acts weird in rain?
duke90
Corona, CA
Hmmm maybe the rain is somehow interfering with the lane assist feature? Otherwise, aside from hydroplaning, not sure what else it could be.
small chance usually lane assist doesn't even work at all unless the lines are clearly marked on a nice straight path. same if driving around with snow on the ground or if the sunlight is at a certain angle
88lance
88lance
Got back from alignment this afternoon, they said it was way off. Of course now since the rain stopped, we might have to wait to know whether it actually solved the problem or not, but it sounds promising, knowing it was not even close to being correct apparently
that's really the only thing that makes sense, otherwise they would be getting associated error messages or "service xxxx" messages
Did you get the typical "before" and "after" detail on the settings? The shop that does mine provides the proof of the initial measurement and final settings.
88lance
88lance
I'm not sure if they did or not actually, I'll ask them next time I'm over there at their house. I guess I may just have to Wait until it rains to have an update otherwise
destman
Of course, if the tires were bad, this could contribute, but it sounds like alignment. Perhaps a bit more toe in for the front would settle it down.
Fingers
