Well.... Then you will probably have to get under there with a meter and start testing for power ground, ohms. You will probably need a diagram to reference and values expected for each pin
Charlie207
LFOD, New Hampshire
For the grounds.... How many are there for the engine bay?
One at the back of the driver's-side cylinder head.
One on the bottom of the block, behind the PS pump.
One on the front of the passenger's side cylinder head.
Anywhere else?
j91z28d1
if the abs module is under the truck around the drivers seat area on normal ones, there's a ground hidden down there for it somewhere too
Charlie207
LFOD, New Hampshire
While digging around for loose wires and other dumb stuff I ripped out the smoked front diff. and slammed in the replacement.
I drained the old fluid from the replacement before bench-pressing it up into position - every ounce counts - and was happy to see that it was fairly clean & no sparkles in sight.
Filled it up with synthetic Lucas fluid. I'll throw in the front CVs some other time. I need a beer.
I'll see if anyone wants to buy the bad one as a core for a rebuild. Does $50-75 seem like a fair price to ask?
j91z28d1
I feel like you might need a month description to all data for this one. that's a lot of stuff
j91z28d1
wired in a toggle switch inline with my hood adjar switch so I can tell the ecm the hood is open when it's not without setting a fault code.
seemed to work on the first test drive.
starnuts28
