Does the wireless charging pad has a dedicated fuse?
salman
Can any one help me to identify the fuse location for center console wireless charging pad?
2015 yukon denali
GMC_nolonger
2015 yukon denali
Did you ever find an answer for this? I can’t seem to find it in any description in the manual and everything else is still working.
Kpwweb
It’s part of the sunroof switch fuse. I think it’s number 10 on the left side dash fuse box?
There is a known problem with the wiring harness for the pad in the lid. The wires are always bending and eventually break. So if your pad doesn’t work and you keep popping the fuse, you have a wiring issue in the console. Pretty easy repair.
diablo124
So how do you repair it
timnow
Did you ever figure this out? I imagine replacing the wiring harness might work. I'm having the same problem. Thanks
CHKSTR96
