09escaladehybrid
- Joined
- Aug 29, 2024
- Posts
- 13
- Reaction score
- 3
This is my first post so any thoughts on this are greatly appreciated. I picked up an 09 Escalade hybrid with about 138k a year ago. It was from the south so no rust and looks really good. Since then, I replaced the tired 6.0L with a Jasper reman, OE cats and a few other parts. Everything has been really good since then until yesterday. I changed the oil and started the engine to check for any leaks. It threw a trans malfunction code 0700 which I cleared but couldn't get the car to move more than a few feet. It had engine rpm but the trans wasn't engaging, so I checked the trans oil. It showed nothing on the dipstick. Zero. That doesn't seem possible as there's no signs of oil leakage anywhere. Garage floor is dry and bottom of the vehicle is also, so here's my question. Where could 7 quarts of trans have gone without a trace? And probably most importantly, will the trans engage when I add the 7 quarts including filter? Or do I have a bad trans that will need to be replaced? Thanks in advance for any help with this.
