Multnomah Falls
20240823_160801.jpg20240823_165743.jpg20240823_165750.jpg20240823_165756.jpg20240823_165806.jpg
I recently installed a new grille and new upper fan shroud on my girl's 1990 K2500. The old grille chrome was separating and the old shroud was cracked in several places.
3 to 4 months back, I did all the light housings.
Multnomah Falls
Are those fender washers OE GM? ;)
Those are left over washers I bought at Home Depot for a Ford Escape catalytic converter shield that had tore away from mounts and needed bigger washers to cover the torn holes. Customer cost of course.
The upper fan shroud install was a PITA. It is new and stiff and perfectly shaped and the lower shroud fought me to line up for all mounting bolts. The holes in the ends at top of shroud were slotted and bigger than the diameter of the threaded bolts. The washers took care of a good solid mount.
the 18th letter
Northern New Jersey
Put a test fit of new 2 me rims and it’s a good news bad news situation. Good news is I don’t need the spacers I was told would be needed. Bad news I didn’t notice the bore size. New offset will be noticeable.
Dremar79
