2013 Tahoe 2 Questions...Enable/Turn on DRL and Disable Auto Door Unlock When Vehicle Placed in Park
herbert77060
1. How do I turn on the DRL on my 2013 Tahoe?
2. How do I stop the doors (especially the passenger doors) from automatically unlocking when the vehicle is placed in park?
tuckerrnr1
Port St Lucie, Florida
DRL should come on automatically when shifted out of park. You can change the lock settings using the buttons on the right side of the gauge cluster.
AUTO DOOR UNLOCK
This feature allows you to select whether or not to turn off the automatic door unlocking feature. It also allows you to select which doors and when the
doors will automatically unlock. See Programmable Automatic Door Lock for more information.
Press the customization button until AUTO DOOR UNLOCK appears on the DIC display. Press the set/reset button once to access the settings for this feature. Then press the customization button to scroll through the following settings:
OFF: None of the doors will automatically unlock.
DRIVER AT KEY OUT: Only the driver’s door will unlock when the key is taken out of the ignition.
DRIVER IN PARK: Only the driver’s door will unlock when the vehicle is shifted into PARK (P).
ALL AT KEY OUT: All of the doors will unlock when the key is taken out of the ignition.
ALL IN PARK (default): All of the doors will unlock when the vehicle is shifted into PARK (P).
NO CHANGE: No change will be made to this feature. The current setting will remain.
Choose one of the available settings and press the set/reset button while it is displayed on the DIC to select it.
H
herbert77060
AUTO DOOR UNLOCK
Thank you very much. I will try the door lock setting in a few minutes. Do you have any idea why the DRLs don't come on automatically? They did on my 2000 Silverado and 2008 Express Cargo van.
t_bergman
Not to be a smart-aleck, are you sure the bulbs are good?
For some reason GM has a difficult time with these; I remember the GMT 800s were notorious for these going bad prematurely as well.
St. Louis
First off, is the vehicle not in the US? Is it an ex PPV/SSV (police or special service) model? If so, it may not have the BCM programed for DRL.
Also I believe there is a fuse in the engine compartment fuse box for DRL
#31
blondie70
There is a fuse for it....I have my fuse out to stop it.
teemassa8314
