1997 Yukon 4x4 front bearing replacement
Doug707
Hi All,
I have a 92' Yukon 4x4, 367,000 miles. Just had "original rivited" ball joints changed. Amazed me too! New here and have question, do you have to change front hub, like newer trucks, or can you just change bearings and seals like we used to do? Any help would be appreciated!
justirv
My knowledge is limited to GMT800 (2000 and later). I see RA has bearings and hubs available for your '92 Yuk. I beleive some may get hubs for convenience sake or for lack of access to a press. If those are original, I'd be happy with sticking with OEM/AC-Delco. I can recommend Timken as well.
Hoesgottaeat2
Western NY
Hub assembly replacement is typically how I've done it on this generation. ^^^^And I like Timken too^^^^
