Chevrolet Suburban 3500 Questions
Geotrash
Dave
Richmond, VA
Should have documented better but can walk anyone thru the process and parts list if needed. Mounted a set of SAE certified Rigid pod lights behind the grill that I plugged into the truck’s factory fog light harness. Works perfect and looks completely OEM. It’s a “cheap” alternative to Morimoto headlight replacements and makes those dark road a lot less dark!
Nice! Which ones did you get? Do you have a link, by chance?
B
Bigburb3500
Senior Member
Pretty sure these are them. The box is downstairs and can confirm tomorrow.
If you want to install them with an independent switch that is pretty straightforward. If you want to use them via the factory switch then it will take me a bit to put the full parts list together.
Geotrash
Dave
Richmond, VA
Thanks, and no need to dig - I would use an additional factory-look toggle switch on the dash, keeping the factory fog lights in place.
Tahoe4
