Browse USB music while driving?
buggsy80
Anyone figured out how to browse while driving on the 2024 Yukon Denali? It seems to limit activity you can do on the drive while driving. Voice commands and DIC don't seem to work either for it.
jgraves
Unfortunately, the only solution I've found is to have my passenger browse for music or podcasts on my phone. Building a few playlists may give you a few more options.
Steve Smith
If the truck senses a body in the passengers seat, you can tap the red dot at the top of screen, and enable passenger mode. This allows you to browse the whole folder. I haven't found a workaround when solo.
jgraves
Now the trick is to make the truck think there's a passenger, without the constant seat belt chime :)
homesick
Bowling ball? Cinder block? Girlfriend?
joe
tgilwright
I still think someone with better smarts than I could figure out which wires to bypass on the passenger seat to make the system think there's a passenger in the seat, and then disable the seat belt sensor and airbag sensor to totally fool the darned system....and their lawyers. And then they would have to post the directions here.
kozzy45
Still no update on this? Just got a new 2024 At4 and this is one of the most annoying things I have to deal with to date LOL
tgilwright
If we could get our meat hooks on a schematic that shows whatever switches send the message to the main unit about seat occupation and seatbelt contact, we should be able to access the wiring harness under the seat and bypass those switches to accomplish the message to the CPU that YOUR girlfriend is sitting in that seat and all strapped in. I was able to access about three hundred albums while driving my 2011 Suburban and never hit anything (well, there was that 8 pound vulture in SW Florida). And the funny thing is that my wife's 2022 Enclave requires the driver to access the big screen to change heating/cooling settings which can be done while driving alone. Go figure.
flipharvey187
