ppvfan
I decided to do it the easy way. Also, I don't care how it looks, so that helps.
![rear-door-speaker-wire.jpeg rear-door-speaker-wire.jpeg](https://www.tahoeyukonforum.com/data/attachments/436/436203-f14849a906525ec1fae7efc5013838d3.jpg)
I cut a small hole in the bottom of the rubber boot on the door side. I didn't want to mess around with the plug connector in the pillar so I drilled a hole instead. From there, it was easy enough to run the wire along the door sill and up to the front. I may put a bit of RTV or similar in the grommet eventually.
I already have 4 Kicker 6.5" speakers installed. Next up will be the Kicker 47KEY200.4 amp and probably the Kenwood Excelon KMM-X705. Any opinions or tips about those are appreciated.
