j91z28d1
Have heard that too!
But then, what difference does it make if it's backwards when the hoses are the same size?
It goes through the heater core backwards? Shouldn't matter?
I believe in general water flows from bottom to top so that air doesn't get trapped?
I don't know haha.
Scrappycrow
Alpharetta, Georgia
I have toe plate with camber gauge as well as turn plates. the problem is my garage floor isn't flat.
My garage isn't flat, either, but I do all my alignments myself and make the floor "flat" under the tires with the use of a water level and a box of plain vinyl floor tiles. To make "turn plates" for the front wheels, you can use newspaper/wax paper layers (alternating 3 news & 3 wax is usually enough) between a pair of tiles, or some thin slick plastic sheets (I used 8573K271 1/32 Delrin from McMaster-Carr).
Christian_d
