Gauge cluster from a Yukon Denali
Wilmington, NC
Hello, I need to replace a gauge cluster in a 2007 GMC Yukon base model and the current one is too burnt out to do the repair for the dim LCD screen. I found one but it's from a 2007 Denali and the gauges are a different color. Is it still plug and play and will it work? I'm assuming yes because the plugs are the same but want to make sure.
I used Circuit Board Medics (https://circuitboardmedics.com/) on my 2004 Yukon denali and they were awesome - Changed over to Blue LEDs - Real nice.
Don't assume the clusters are the same. I had to replace one and it can be tricky. The part number on the back has to cross reference to your old cluster. A parts person on ebay if you want to buy used can help with this issue and if they are wrong they will help you if they are a rupturable seller. They sent me one for a chevy pickup but I needed it for a GMC SUV. Just saying!
typically it goes by the year and not always necessarily the model for crossover purposes. I put a Cadillac cluster in my (old) silverado for instance and I have a police cluster in my denali. I could also put a denali digital cluster in my current silverado if I wanted to....
correct not to "assume" but there are a variety of choices and endless customization
jeraldlklee
