Put a new one in the Silverado as well, lots of fun when there is a ton of crap hooked up and in the way, have to move the reservoir out of the way too otherwise that bastard ain't coming out, just in time for it to start raining1000006054.jpg
wow all that is on top of the battery?
ya the k2's have a integrated fusible link/ multi-fuse that sits on top of the battery, I just happen to have extra equipment hooked up as well winch, amps, air ride, air compressor, lights, etc
I burnt one of the links out before that plate is about $120 and not repairable. It's split into different ratings like 40a/80a/120a, something to that affect
sometimes if one of those burns out you get a no start situation, or half the vehicle will not work and unless you check each link with a meter you can't tell and it leads to all sorts of headaches, it's came up a few times on the k2's
89Suburban
Bull in the china shop
SE PA
New Mohicans hopefully these last as long as the last ones View attachment 442506
I just replaced mine last night. It was 3+ years old and Sunday night it gave me the 'ol Whrr, Whrr, slow crank, *** puckered up. Did ok for a day. Then Tues night, same thing. NO WAY brother. I jumped right on that sht!!! She's very happy now. :)
Mine were almost 5 years old which is a stretch for here, it gets so hot and then now that the temperature dropped I could tell they were getting weak, it was time.
I have a charger that will give like a 50a start boost if needed but haven't had to use that thing in good while when I had the 03 silverado it would sit for a few weeks sometimes and go dead.
Geoffsfas10
St. Louis
Here's a random one for you...
You think my rear liftglass would be fine for like a 2, maybe 3 miles drive open? i need to bring some 14' pieces of crown moulding home, last time i put them on the roof rack they snapped. I would imagine for such a short drive it should be fine. max speed would be 40 and thats only for maybe a mile
just super granny it and yes, by that I mean accelerate and brake very slow and leave a big gap in front of you if traffic has to stop
EGDinSD
