Final call!!
master_painter
What's going on gentlemen so I've decided to go ahead and replace the whole entire rear end but I'm nervous by what everybody's been telling me I have a 03 Tahoe Z71 I'm getting a rear end out of a 06 Escalade the gear ratio in the stock 06 Escalade should be compatible for the front gear ratio of my four wheel drive on my Z71 correct
wjburken
Eastern Iowa
Not trying to bust your nuts but, I’m a little confused as to if you are asking a question or just sharing information. Can you please break you post into a couple sentences with some punctuation?
Trey Hardy
Eastern North Carolina
You need the rpo code from the Escalade to verify with your Tahoes rpo code so you can see if the gear ratio is the same
Is the escalade rear a 14 bolt or is it still a 10 bolt?
As long as you verify the gears are the same then you should be good to go. You can also pull the diff cover and count the gears if you need too
Multnomah Falls
Yes, welcome to the forum.
You do need to verify, with matching RPO codes, that the gear ratio is the same.
Also, like @wjburken said, one long sentence is confusing and will drive some members away when trying to help, me included.
Here's the background thread. I'll let y'all jump back and forth for exercise.
M
master_painter
I counted the teeth on the big gear and it's 41 I haven't got to the pinion gear yet
Sorry I'm new had grease all over my hands I'm trying to figure some things out voice text so I can't help it it didn't put punctuation in forgive me I'll try to do better next time
wjburken
Eastern Iowa
You can usually get the gear ratio simply by turning the drive shaft and counting how many times you turn it to get the rear wheel to go around 1 time.
Trey Hardy
Don’t feel bad I’m the same if not worse
GetGood
