Help me decide what to do??
Fless
Super Moderator
Elev 5,280
@Mudsport96 suggested a method to test the ratio of the front diff, but that can also be used in 2wd for the rear diff:
Fless
Super Moderator
Elev 5,280
Not sure why you wouldn't keep this in one thread. See this one for the "decision":
M
master_painter
I am new here sir stop busting my balls!!!
S33k3r
Dallas, Texas
I've never seen @Fless bust anybody's balls -- he just doesn't work that way. He was just giving you a friendly reminder. This is not a forum where anyone enforces anything with a heavy hand -- EXCEPT civility. One person in particular had ******* behavior (he wasn't a total dick), and members brought it to his attention.
Please consider this: No one here is going to be a dick to anyone. This is too valuable a site, with too many valuable members to cause any kind of stupid internet fight.
If someone says something to you that upsets, set it aside, and come back later to look at it from the point that no one means you any grief. To be clear: We don't! (I feel very condifent in speaking for everyone on this!)
To hopefully answer your question, here's a little help:
You need your gear ratios to match, front and back, or you will destroy your transfer case (as well as having the JERKIEST ride of your life. Think "bucking bronco".) The RPO code GT4 represents 3.73 gears, and GT5 represents 4.10 gears. You need to understand what you have in your Z71 -- which is likely GR$/3.73, and what the Escalade has (which is also likely Gt4/3.73). If the codes match -- and no one has done any "customizing' -- you should be good to go.
Good luck!
Mudsport96
40.923,-89.488. Illinois
That's the problem I don't know what the back is to match the front. But my rear end is screaming at me so I have to move it one way or the other.
This here tells me it would be far easier to swap the whole rearend. If your diff is "screaming" there will be enough debris in the whole assembly that all the bearings are trash.
lordmorgul
