p1153 even with 2 OEM o2 sensors
WeekenderNutJob
2008 Yukon XL Denali, 6.2L AWD - P1153 (Bank 2 Sensor 1) code even after replacing the o2 sensor.
Replaced Sensors: About a year ago I replaced both the upstream and downstream sensors on that side with AC Delco ones of the same part numbers when it had codes, which worked well for about a year. Recently started getting just an upstream sensor error, p1153, so I replaced upstream again with OEM, cleared all codes, and ECM memory reset, however, I get codes again after the drive cycle. At this point, I am not convinced it's a sensor issue anymore as the OBD Reader shows that the sensor voltage is working similarly to Bank 1 sensor 1.
Smoke Test: The next assumption was an exhaust or vacuum leak, so I smoke-tested the exhaust from the front intake and from the back exhaust for a potential manifold or vacuum leak, but I did not find anything indicating a leak anywhere on a cold engine.
TSBs: As a side note there is a TSB (https://www.tsbsearch.com/GMC/08-06-04-045A) that talks about the need to reprogram ECU due to gas sulfur levels but I assume if it was an issue with the sensor and ECU reprogramming after an o2 sensor, then it would have been an issue when I replaced the upstream originally a year ago. I always run 91+ octane gas, from top-tier stations, per the manual.
Before I take it to the dealer, for more diagnostics, or ECU reprogramming, does anyone have further suggestions on tests I can do?
W
WeekenderNutJob
Hoping to bump this for any feedback. Still not able to isolate the issue. Here is what I have done more since the last post:
Connections: All clean and good.
Fuel pressure: About 60-65 psi key on but not running, and 42 when running which seemed somewhat low...but within the low range of "normal". Fuel pressure is maintained when the key is off and after 5 min.
Injector cleaner: I also am running some injector cleaner through it in case maybe it's a clogged injector on just that passenger side.
Coolant: No use of coolant to suggest a contaminated exhaust.
MAP Sensor: Cleaned recently.
Is the fuel system management going into closed loop and staying there?
I would be curious about the short- and long-term fuel trims (both banks) and what the MAF is reporting at hot idle, if you have access to that info.
j91z28d1
any chance you have an aftermarket airbox of some sort?
W
WeekenderNutJob
Nope, bone stock.
Yes the fuel system management is going into closed loop and staying there. Short term and long term fuel trims are lower on bank 2 versus bank 1...but I don't know why. Should I pull the fuel injectors out and test them one by one? Or at least ohm out? My next test I think was going to be either a stethoscope on each injector, or a back pressure test on the catalytic converters.
Would still like to see the MAF reading in g/sec at hot idle, just to be sure it's close to engine displacement. And hearing that the fuel trims are lower on one bank than another doesn't really tell much. Where are they numbers-wise? Do the trims change a lot when raising the RPMs to 1500 or 2k?
The upstream sensors can be swapped side to side to see if the issue follows the move.
You can test the injectors without removing them by doing an injector balance test. You'd need a scanner that would do that, though.
W
WeekenderNutJob
See attached data. Trims don't change much at 1500 or 2k rpm. Even though the sensors on bank 2 sensor 1 and 2 are either brand new, or replaced last year. I think I'm going to swap out the Upstream sensors this weekend and see if the code follows the sensor. And if that doesn't work I guess I'm going to be buying a better scanner with injector capabilities. Currently just using a cheap Bluetooth OBD scanner and the "car scanner pro" app. But I have had my eye on some Harbor Freight upgraded scanners. Anyone have any good suggestions? Maybe something that can actually tell me what injectors are doing.
Also for this weekend would be pulling all of the spark plugs and doing a compression check on each cylinder. Maybe I have low compression in one of the cylinders on the bank two side. Even though there's no misfire data.
The only thing that stands out in the screen shots is the sum of the short- and long-term fuel trims for Bank 1; everything else seems okay. Being that close to 10 deserves a closer look at some point, but is likely not related to the current code on Bank 2. (Bank 1: dirty injector? Verify all the intake bolts are tight to spec?)
If the sensor swap doesn't cause the code to follow, then -- and this is a long shot -- I'd be pulling the top of the underhood fusebox and inspecting and reseating the connectors, watching for pin arcing or other circuit issues. So far this is a head scratcher but I think your data and work will eventually indicate the cause.
j91z28d1
yeah adding 10% fuel to bank one seems a bit high. usually that's closer to +/-5.
not that that helps you much. but yeah, maybe it doesn't like the split. if you swap sensors be interesting to see what it does.
I believe you can add pids to car scanner app if you can find your injector ms pid. it's usually only bank 1 vs band 2 thing. not all 8. the refresh rate is to slow for that to be much help anyways
torque pro might have it with the add on gm pack. but I don't remember forsure and I believe it's only for non iPhones users. but it would work with the same dongle and you can definitely add any pid you can find for it.
bruh2125
