89Suburban
Bull in the china shop
SE PA
Works fine.
It was fun watching instantaneous economy. Low of 3mpg up to 59. One is closer to reality than the other.
Are you going to reach out to Range about the issue with the bad one? Maybe there is a reset or something.
these clowns are not offering lifetime, they know better
Warranty InformationTo request warranty service please email [email protected] or call 1-866-404-6141. Range Technology warrants the covered product to be free of defects in material and workmanship for a period one (1) year from date of purchase. This warranty extends to the original buyer only.
that being said, some places offer a trade-in or flat rate repair which is cheaper than a new one, might be worth a shot
Sparksalot
Bastrop County, Texas
I was half thinking of popping the case open to see if there was something obvious that jumped to my attention.
j91z28d1
finally got around to checking alignment after seeing feathering on the outside of my front tires.
almost a half inch of total toe in.
blah but luckily the tie rod adjusters broke free pretty easily. set it I just a touch negative and let it ride.
camber looks like -0.25 drivers and 0 on passengers. I didn't mess with it since I figured that's within the spec of my floor haha. ain't a flat spot in it
89Suburban
SE PA
Toe plates?
j91z28d1
Toe plates?
I have toe plates that also do camber. but honestly find it eaiser to setup string between 4 jack stands. I find toe plates not every repeatable when you're playing at an 1/8in range and they don't fit well with my turn plates. so oddly I use my toe plates for camber haha.
SPIS
