Replacing Flexplate, what else is needed
DFletch
I have a 2008 Yukon XL Denali AWD with a 6L80 trans and a 6.2L engine. Since I’m going to be replacing the Flex Plate is there anything I should replace since I’m going to be in there? Also if there’s another Thread that already covered this please point me in its direction because I couldn’t find it
Charlie207
LFOD, New Hampshire
^^^^^^^THIS^^^^^^^
Might also consider getting an upgraded torque convertor.
This is a decent upgrade/replacement: https://www.summitracing.com/parts/ccv-tqbu60fhd
D
DFletch
Thank you for the advice everyone, it is greatly appreciated. Should I do anything with any of these parts as well, aside from the RMS?IMG_5438.png
What's wrong with the flex plate?
j91z28d1
Thank you for the advice everyone, it is greatly appreciated. Should I do anything with any of these parts as well, aside from the RMS?View attachment 443747
yeah, what's called out as 519. the cover gasket. pretty common leak. most get the new plate with the rear main already installed too.
watch some videos, there's a little bit of alignment to watch our for. they sell alignment tools, but I'm not sure it's needed. Just make sure the rear main is centered before tightening down that plate
if you have it apart enough to get the oil pan down. replace that gasket too. they all leak at some point.
D
DFletch
Recently took it into a transmission shop to get the transmission programmed and they said that the sound the trans was making was from a crack in the flex plate. They said that it shouldn’t be a problem for a while but it’ll be annoying as all heck lol. That’s why I want to replace it
I've cracked 2 flex plates--2 different GM vehicles. It sux. Good move on replacing it now rather then later.
TooManyCars
