Nitrogen?
Mean_Green
Mean_Green
The cost for a home rig is cheap once you get the initial investment out the way.
And that is?
I don't drive enough for mileage to be an issue. They sit in the garage 29 days out of each month. But I'm curious about slow leaks and I might even use it in lawnmower tires for the same reason.
wjburken
Eastern Iowa
And that is?
Not sure how nitrogen will help with slow leaks. A nitrogen molecule is .305 nanometers in diameter while an oxygen molecule is .299 nanometers. A human hair is between 60,000 and 100,000 nanometers. Pretty sure if there is a leak point that will let air out, it will let nitrogen out as well.
PPV_2018
U.S.A.
And that is?
Cost can vary depending on the brand and quality of equipment. Biggest variable is the tank, which cost significantly less used than brand new (& can usually be found easily on Craigslist or fbmp
But you can do the whole set up for roughly $150 (plus fill) assuming you get a used tank for around 60 bucks. Can buy a regulator for around $40 and the couple feet of rubber hose and the brass sittings required for less than $50. Oh yeah, and you’ve got to take it to get filled, less than $20 locally at welding supply shop.
My set up was around $240, that’s because I sprung for a quality all brass regulator and the quick connect which was not required, just makes it easier. The only true consumable is the hose which is susceptible to dry rot if stored improperly. Everything practically lasts forever if you take care of it.
And that is?
My home compressor setup, which I've had for years, cost me about $350 at Harbor Freight, which included a 4.5 SCFM compressor and 21 gallon tank, 50 ft. of hose in an enclosed, spring-loaded reel, and the tire inflator device with pressure gauge. Of course, tire inflation is only 1 small use case for this equipment, with many other uses across the year.
I will note that I previously purchased 2 different $100 'small' compressors (120V AC, but really a 12V DC motor) with pancake tanks (Husky and Rigid), and they both failed within 1 year. Maybe, it was just me, because I see these small compressors in use in many places.
Well I agree, and If we’re going to make a point about gas purity standards; then no gas is “pure”, there is no such thing as a “pure” gas, which is why I put “pure” in quotation marks and referred to this “pure” gas that everyone speaks of as “straight”. Maybe you could come close in a scientific laboratory in a tiny volume strictly for experimental purposes, but even then I doubt it, most gas used scientific (read: highest purity, aka UHP*) research and laboratory precision testing usually has the impurities accounted for.
The same can be said for both industrial and medical gas classes. No grade of gas, neither industrial, UHP (ultra high purity*), or medical is 100% pure. Likewise, even medical oxygen and what is dubbed as “breathing air” is NOT 100% pure. Generally, the standard for industrial grade “purity” is >99.9995%, but could be higher or lower depending on the particular batch. Each batch of air separated nitrogen is analyzed and given a COA. Similarly, medical and other UHP standards are, as you suggest, more stringent. The exact percentage can vary, but again generally we’re looking at >99.99990% or higher in that regard. Said all that to say, that no gas is pure. It doesn’t exist, therefore it should be referred to as straight nitrogen.
So while yes, we’re talking about tires, actual industrial nitrogen “purity” is still pretty good, and if we’re taking the advantage vs disadvantage of nitrogen in tires to a scientific level, then roughly 22% difference in nitrogen content in “straight n2” versus atmospheric air *could* make a difference if each tire was filled completely with n2.
One interesting point mentioned above is the atmospheric air residue in the tire which would make it impossible to fill with 100% straight nitrogen. I suppose this could be a factor, but also believe that the tire could be purged out with n2 via the valve stem if the tire was already mounted on the wheel. That I’m not too sure about, but if anything it would reduce the percentage of atmospheric air to a lower amount, even if not 100%.
Of course, I do not disagree that the benefits are, or could be, at best, negligible — which I made a point to emphasize in the post. I suppose the factors and variables in each particular application could provide more or less “benefit” of n2 filled tires. There is a reduction of friction between the tires and road with the lighter gas, and a noticeable difference could rely on many factors, but one possible variable is that much larger tires, such as heavy A/T off road tires or medium and heavy duty truck tires may benefit more from n2 fills than our Tahoe’s.
But one point that I would like to add, for the cost of the fill of that n2 tank, I spend roughly .36 cents for a full tire fill @ 40 psi. If a gas station compressor costs you 1.25, for filling surely less than 40 psi, then over the years there is actually more potential to save money from paying to use gas station compressors, or even buying a portable air pump which I had mentioned in another thread vs. saving money from better gas mileage. Add in the convenience factor of being able to fill any tire, to any psi, in literal seconds is another reason why I have the rig, but hey, to each his own.
If you really want to experiment with better gas mileage, you could try filling your tires with helium… of course, remember to take out an SBA before you go :)
This has been a great group discussion, and folks here have the information to make their own choices. This is what this Forum is all about (versus the BS that flows like lava on Facebook and X). This is yet another example of why this Forum ROCKS!
Just for giggles, I've attached a few photos of the 100% O2 and 50%/50% O2/N2 tanks (300 cu. ft.) and gear that I used for my decompression stops during my wreck dives. I also used 100% Argon in my dry suit, since it has 4 times the thermal insulation value as air. This is how I got involved with custom gas mixes.
15burban
Wisconsin
Fix a flat or slime works great for slow leaks in atv/lawnmower tires. Going on 7 years since I put it in one tire on our polaris. I've never had to air it up since.
homesick
Divers do it deeper?
joe
Champ74
