Chasing a rough idle?
It's the upstream (pre-cat) O2s that are disconnected, right? Makes no sense that it would go into closed loop without the O2 reporting.
Also with the O2s disconnected you should be seeing O2 heater circuit fault codes.
2009TahoeLT
that's kinda weird it's still removing 8% fuel with the o2s unplugged.
is it possible to clear/reset those? I was expecting trims to be stuck at zero with the o2s unplugged.
edit, and it's in closed loop. yeah that didn't work at all lol.
They were stuck at 0 until it warmed up a bit. Then they started bouncing around again
j91z28d1
refresh my memory. an intake leak it needs to add fuel for the extra air right?
2009TahoeLT
Yeah I unplugged 4 of them I believe. Might have been 3 but definitely 2 pre cat were unplugged
2009TahoeLT
Yeah I reset the o2s before but I didn’t reset when I unplugged them
j91z28d1
I've used the test before on older trucks at work to test of something is bad. usually you can unplug it, it default to a set value and judging by if it runs better or worse. it can help you what a direction to go in. but since I've not actually tried it on my own gm truck, is it possible it can look at the rear o2's if the front are disconnected? new one in me.
either way, my thinking is your ecm is removing 8% long term and 8% short term. that's enough fuel removed its going to run bad from being lean even if everything else is correct. so need to find out why it's doing that.
did you notice if it ran any better while the trims were at 0 while warning up?
Yes, unmetered air dilutes the mix and the O2 sensors add fuel to compensate. Positive fuel trims.
markstaho
