HD Centerlink on 2003 Tahoe Z71?
dps01
N. TEXAS
Rebuilding the front end of a 2003 Tahoe Z71 in the future. Vehicle is leveled, not lifted.
An aftermarket steering stabilizer is installed using a U-bolt kit. It works and steering is improved, but looking to use a centerlink with provision (hole) for a stabilizer when much of the front end will be apart.
The overall length of the centerlinks:
Original (1500 series): 28.75”
HD series: 30.5”
Total of 1.75” longer
Can the existing adjustment range compensate for this change in overall length?
Is the thread pitch / size compatible to use the 1500 series tie rods / end links?
Still in the investigation stage…
Had this been done by anyone?
Don’t want to reinvent the wheel.
Searched the forum did not come across an answer.
Trey Hardy
Eastern North Carolina
HD series: 30.5”
I believe the inner thread pitch is bigger maybe go to advance or AutoZone and ask to see both inner tie rods and compare with a dial caliper?
Worst case you could bring it to a good machine shop to have it welded up and re tapped for a 1500 style tie rod? I had the duel stabilizers on my 99 but I had a 6” lift and the one end bolted to the crossmember drop the other ends u bolted on to the tie rods if I remember correctly
dps01
dps01
N. TEXAS
Agreed.
May have to shorten the tie rods as well to accommodate the increased length of the HD centerlink.
Trey Hardy
Agreed.
With my lift kit we usually got to cut a inch off the inner tie rods anyways to get the alignment done so that shouldn’t be a issue I wouldn’t think
dps01
dps01
N. TEXAS
Thanks. That is good to know.
KRYPTONITE makes a nice upgrade for the HD trucks…. but it is high dollar stuff…. May put a call into them as well to see what their input may be.
I am planning on using their front hub / bearing when the time comes.
Marky Dissod
Looking forward to seeing what fruit comes of this.
I'm cautiously optimistic about using 2500-type steering / suspension parts on my Tahoe.
Also researching how to use an H2 rear swaybar ...
NYC Metro
I have a 2500 Yukon XL - I had a 1500 Yukon XL - not much is going to cross. Nothing in the rear. If you look at the part #'s - not much in the front. I bought off the shelf Hub/Bearing assemblies - Good Bearings - Timken or NSK were the bearings in the hub. Original went to 110K? next set to 225? Final set went to the yard at 270K. I don't see much value going to a specialty product to solve a problem that does not exist - one of the ones that came out at 225 was damaged on the back by rust / road debris - hey I live in NY/CT - so it happens.
I have considered looking at the Cognito reinforcement for Idler and Pitman - but it's spendy for a few braces.
Marky Dissod
It'd be nice to compare 1500 vs 2500 front suspension & parts side by side, to actually see the differences.
Simply noticing that part numbers are different is not sufficiently discouraging -
to me, at least. My definition of 'GM OE' is FAR more flexible than most people's.
Anybody out there got a '1500' AND a '2500' that they can line up side by side,
to see WHY 2500 parts are incompatible with '1500' vehicles?
Snikelynn1
