Brake light and no traction control light on with service brake system and stability sys disabled 2004 GMC Yukon XL 5.3
Ak0924
The front brakes were compressed during a brake job to turn the rotors, the rear got compressed to turn the rotors and get new pads. No caliper hoses got pinched or abs wires got pinched. When I drive the vehicle with a scan tool I have correct speed to each of my wheel speed sensors. I tried bleeding the brakes, bleeding the abs and tapping the brake fluid reservoir to unstick the float. Problem still persists.
What codes are pushing the warning lights and messages?
A
Ak0924
No codes are present, I even hard reset the computer and the lights came back on
Are you using generic OBD or the manufacturer's code selection? Generic OBD won't read them. And read them while the messages are on the DIC.
A
Ak0924
I am going there the manufacturers code selection, there are no codes present
A
Ak0924
Everything just to be safe. Engine, transmission, Body and ABS.
A
Ak0924
I understand that there is supposed to be a code. I am telling you for a fact there is not one. That is why I am troubled
Yukonultimate23
