AlphaZulu
- Joined
- Nov 30, 2024
- Posts
- 6
- Reaction score
- 7
I didn't notice that until I was uploading the pictures, and now I'm second guessing my order. I think I probably have them reversed, and the two wrong ones are #3 & 7, which were my misfire cylinders. So much for government maintenance. The new plugs are all matched and correct.Hope the new plugs are the same, because the ones you removed are way mismatched. Nos. 1 & 5 were a different heat range than the others.
@Rocket Man shows the tool setup for the #8 plug:
spark plug change 5.3
So i decided to change my plugs on my 2008 Tahoe after a 125,000 miles, the driver side easy to do but the passenger side little more difficult. So i removed the inner wheel well liner and used my dewalt clamp to push the AC lines up to access the rear plug, see pic. Hope this helps someone.www.tahoeyukonforum.com
Nice catch.
