7 pin connector trailer plug
Dimbagbubba
Looking for 7 pin wiring diagram that doesn't have a white wire as the ground. My 2003 tahoe factory 7 pin trailer plug doesn't have a white wire.
Dimbagbubba
Dimbagbubba
Idk yet but its a helluvalot closer than anything I've seen on the interwebs in the last 4 hours. Thanks. I believe it'll do the trick. First thing I've seen where a white wire isn't the ground.
Ima try it when the sun and temp rises a lil bit
That diagram appears to be the harness connector that will attach to the back of the actual 7-blade connector that's on the hitch.
EDIT: from Rock Auto
Dimbagbubba
Dimbagbubba
They are the exact same colors as the wires that go into the back of the "actual 7-blade connector" that i plug my trailer lights into. Fingers crossed they work. Going to look good mounted to the left of the license plate!!
Are you wiring direct to the 7-blade connector, or just re-doing the harness connector?
Dimbagbubba
Dimbagbubba
A new 7 pin connector. My old one got ripped off
BrancoRST
