1995 Yukon High Idle
Steven94
My 1995 Yukon is having a high idle issue and I've already replaced the EGR valve, EGR Solenoid, TPS and its still having issues any help is appreciated.
B-train
Check the gasket under the TBI unit. They are known to crack and disintegrate with age. This will cause a huge air leak and allow it to run faster. Thise didn't use MAF sensors, so the engine doesn't know it's getting more air than it realizes.
Eman85
95, is it a Vortec engine? If TBI then it's most likely the throttle body gasket. If you have a scan tool check IAC and see if it's being commanded closed, if so it's a vacum leak. A smoke generator is a good way to test for a vacum leak, easy to make one from PVC pipe and Youtube videos.
S
Steven94
Would a vacuum leak also cause it to have a low idle? Like low to were it sounds like it’s about to die?
Eman85
Let's all get on the same page here.
Is this a 95 with a Vortec 350??
You said you had a high idle now you're talking about low idle.
S
Steven94
Sorry, 1995 Yukon 5.7 it has a low idle when turning on like 500 rpm almost to the point of dying. Once your driving the rpms will shoot up to about 1500rpm if you put it in park. While driving at idle at a light or stop sign its around 800-1000rpm. I have changed the Egr valve, Egr solenoid, TPS, and the Idle air control valve to this point.
Eman85
Is it a Vortec motor? Have you checked for any codes? Did you clean the throttle body and mass airflow sensor and check the air filter and all of the intake duct hoses? Have you checked for any vacum leaks? Do you have a scan tool with the ability to read live data? How much money is in your checkbook to keep buying parts? We can fire the diagnostic parts cannon if you want.
angelmar650
