There are just some days I wish I didn't turn wrenches
Multnomah Falls
Did the 2020, not a 2019, Corolla XLE this morning. Manufactured 01/2019 and I ASSUMRD was a 2019 Corolla. The different air filter size is what made me look again. The only things that did not cross over were the air and cabin filters. No biggee, quick trip to AZ and the same prices. Oil change, reset maintenance reminder light and put sticker on w/s, aired tires to 40 psi and the TPMS light went out and rotated, cleaned MAF and throttle bore and installed filters. Checked belt-Good. Wipers-Good. Close to the tire wear bar indicators. She plans to get tires in Spring and just drives around town. No trips. Brakes real thick and even wear. Brake fluid and coolant and P/S fluids all good.
Ship it.
mountie
Ship it.
This next year, I'll be diving into this '69 thing.... ( It's all there...... no real rust.... California car....
  • rear 3:4.jpg
    rear 3:4.jpg
Multnomah Falls
Had ordered in headlight assemblies for next door neighbor son-in-law for a 2015 Altima S.
Got at it today. Replaced because the OE lights were fogged and scratched. PITA to get apart and back together. 3 hour labor job, start to finish. Pics:
Jake707
Fairfield, CA
A few months back I helped my nephew get his "project" 2004 Honda Civic 2.0 running, what a nightmare that was with random electrical and fuel delivery issues. Last week I got a call it was was making a knocking noise so I go check it out annnnnnnnd he rod knocked it somehow haha. He asked me how we can fix it and I tried not to laugh to hard and just told him there is no "fix", the whole thing needs to be torn down for rebuild or replaced. No secret sauce or part swap is going to correct it and a new motor is more than the car is worth. While I dont want any part in a motor swap on that car, I couldnt leave family hanging if they decide to salvage the car.
My sister/brother in law arent the mechanical type and my nephew is at that "know it all" stage and somehow talked them into this project rice rocket as his first car that he would be able to learn to wrench on. So I knew these series of bad decisions would ultimately pull me in eventually haha, I just wish it was something I thought was cool/fun haha
Multnomah Falls
My closest relatives are in the KC, Mo. area. My youngest brother, 2 middle brothers are deceased, is very mechanically inclined and never calls for advice. He doesn't dare. He likes Fords. I would just tell him to get a Chevy. He works for Ford assembly plant in KC, so I guess he will just have to suffer with the Fords. My cousin Bev has a fairly new Tacoma and has not called about anything on it, yet.
I have American Legion friends and VFW friends. They know my rules and call when something is actually needed and typically follow my advice.
The busiest I am is from my neighborhood and their friends/relatives.
I am starting, this morning, on a 2015 Town & Country mini van with a P0740 transmission torque converter problem but when I add fluid and clear code, the CEL stays off. I am addressing the obvious transmission fluid leaks this morning, the transmission pan seal/gasket and the leaking cooler lines. The dealer gave him a quote of $980. He paid $190 for a 35 minute inspection for leaks. I had done a recent oil change and pointed out the fluid leaks. He said he would take to dealer for inspection. I said, "Ok, let me know what they find". He did. Me fee today will be around $950. LOL!
homesick
$30 saved is $30 in the bank.
joe
Multnomah Falls
joe
No, he had a little over 4 hours labor and I beat the total quote of $980 by $400 even. All parts and fluids and labor and road test with scanner hooked up monitoring engine temp and he paid for the new transmission dipstick to check some of these no dipstick vehicles.
Multnomah Falls
So, I dropped the transmission pan, caught all the fluid, cleaned transmission pan mount surfaces on transmission and pan and cleaned the magnet and reinstalled,
replaced the filter, installed pan, went to the top and removed the upper radiator core support. Disconnected the transmission cooler on left side of radiator so it would flex out and give me room and wood blocked the grill forward for more room, cleaned the spring clip mount areas for the transmission cooling lines, used my disconnect tool for removing the lines from the spring clips at the transmission and cooler. Cleaned all up and lubed the tube ends for easy reinstall at the transmission and cooler. Reinstalled cooler to radiator and reinstalled upper radiator core support and bolted all back together. Put 4 quarts of transmission fluid in and checked level with my special dipstick and compared reading to graph for engine temp. Capped off the fill tube and road tested. Got to 208 degrees on my scanner and rechecked fluid level and added 1.5 quarts to bring up to full reading at that engine temp while running. Road test again and checked for leaks. All good.
20241230_105253.jpg20241230_111006.jpg20241230_105156.jpg20241230_124616.jpg20241230_124626.jpg
homesick
Now I'm confused. From your post...
"... The dealer gave him a quote of $980."
"... Me fee today will be around $950."
joe
Multnomah Falls
joe
I was bragging how much money I was gonna save him and threw out the $950 as a joke. Although, the two jobs I did in last 2 days, got in under the wire. I am raising my labor rate to an even "C" note as of the 1st.
I knew I was gonna save him some money but it turned out to be an even $400 savings. Very happy guy.
dry_fly
