1995 Yukon High Idle
east302
Mississippi
Once your driving the rpms will shoot up to about 1500rpm if you put it in park. While driving at idle at a light or stop sign its around 800-1000rpm.
Is it happening only when the brakes are applied (brake booster)?
GM published diagnostic procedures in the manual. The link is in post #6, but here is an example from the 95 manual:
GMCChevy
Senior Member
At this point rather then continuing to throw psrts at it you should probably use a scan tool thst shows what the different sensors are reading so you can either pinpoint which one is bad or what reading isn't at a normal level.
S
Steven94
Waiting for it to come in
SlimTheTech
