No start? check in here.
j91z28d1
some files that might help with no starts, I see threads all over about when these hybrids don't start and there's just so many reasons.
nothing about these crank like a normal car. the learning curve is kinda brutal if you haven't been into trouble shooting electronics in newer cars for a decent amount of time.
plus most dealers and shops techs aren't willing to waste their time on this stuff. they will mostly run up your bill till it's more than the truck is worth and leave you with a no start and a recommendation that you need yet another high price part that is probably discontinued anyways.
so hopefully this can help at little bit.. along with a good bi- directional scanner. like a tech 2.
  • HP2 diagnostic system check.zip
  • HP2 engine will not crank.zip
  • HP2 high voltage system inspect.zip
  • HP2 high voltage enabling.zip
J
j91z28d1
just to add to the no start.. one of the harder things to track down seems to be loss of isolation of the high voltage. it can be anything as small as the wrong oil used in the ac system by a mechanic that doesn't know electric compressors. the standard pag oil gets conductive over time. so you gotta use poe. also the main orange power wires are run in conduct to protect them, but it is possible they have been damaged and lost isolation. at any point the truck sees that some place it's not supposed to be, it will not close the contacts and you're dead in the water. since the 300v is what cranks the engine over.
because it's hard to track down, gm released a tool that will simulate the high voltage inverter or the drive motors depending on which part of the troubleshooting tree your at. it's called a EL-48458, they used to be very expensive new, but all over ebay for under 100$ these days.
here's a short walk thru of hooking it up.
  • EL-48458 High Voltage System Dia.zip
abdalk
Hi
sad story, I live in Canada and i slide into a ditch lightly tapping a tree, my side airbags went off. no damage otherwise slight dent to the A pillar. Anyways now i have to scrap the car because I am told everything needs to be replaced for the codes to be cleared. It starts but it does not crank.
Any suggestions?
Thanks
J
j91z28d1
2012 cadillac escalade hybrid
can you describe starts but doesn't crank?
your best bet is to buy one of the China tech 2. they are about 300$ these days. that will do dealer level resets. I have one and it's very handy to have
I don't personally know much about repairs needed after air bags go off. I would hope it's the same as the non hybrid trucks. replace the air bag. used if possible, replace any sensors that might have set. and then take the tech 2, try to clear the airbag codes and see what happens. that should lead you to any other issues in the air bag system.
there is also a vehicle has been in a crash code that will disable the hybrid system. I've seen threads saying it can happen if you hit a big enough pot hole. the tech 2 can clear that code as well.
any pics of the truck? I like these hybrids but the down side is you kinda have to fix them yourself. there's just not a lot of support for them.
willylump
