Yukon rear storage options
martone
I recently purchased a 2024 Yukon SLT and looking to find existing rear storage options. I've used the jack compartment and shallow storage inside the lift gate but need space for a small air compressor. Any thoughts?
motorswin
Can you mount one under the car like the on board systems guy run for air horns or filling up tires?
KMeloney
Is your compressor smaller than a battery?
There is a space behind the driver side panel in the cargo area that holds the second battery in the PPV.
Is that where the sub is on non-PPVs though?
Outahere
I have a 2016 Yukon and there is room under the hood opposite side of the battery if the compressor isn't too big.
M
martone
Thank you all for your responses. I guess aftermarket is the solution for me.
Rmcoy0017
