08 intermittent door speakers
stangcrazy84
As stated 08 lt2 I believe every option except navigation and DVD factory everything speakers head unit no Amp just factory as produced
To no rhyme or reason just door speakers will quit like Copperfield boom gone dust in the wind and then random as it went it returns it can be at idol running parked up hill down hill across no reasons just in and out
I'm leaning on the HU but a lil guidance would be helpful
Have you done anything to the stock audio system (doesn't sound like it, but want to be sure)? Have you done any work under the dash in an area close to the head unit, where you might have inadvertently moved or disturbed a connector on the head unit? Are all of the door speakers cutting out at the same time, or is it only 1 door involved?
S
stangcrazy84
Never been inside the dash at all I have owned it for about 10 years and it's done it since the day I bought it
And yes it's all 4 doors at once
Thank you
Shimmy23
WA
first check your fuse panel under the hood. there's a key in there so find the amp fuse and check that first. If its fine, move to the connections/plugs on the speakers. wiggle the wires on each speaker. let us know what you find out.
S
stangcrazy84
Will do but I don't think it came with a factory Amp?
me51
Germany
I think intermittently working door speakers are a somewhat common issue on these vehicles. One of my front door speakers cut out once in a while, but I replaced both sides a couple years ago with GM parts (due to Bose system and Bose-specific ohm value) and no problems since then.
Is there still sound coming from the A-pillar speakers and rear doors?
S
stangcrazy84
It's just tje a pillars and tje ones in the hatch
No door speakers at all
I guess it would be easier to replace a speaker than pull the HU
Your amp is under the cup holder/tray in the console. Just in front of that is the subwoofer.
Check the wires going through the door. Being 16 years old, I reckon they're due for replacement. Did almost all of mine in '23.
The tweeters are wired to the radio with the front door speakers. The rear door speakers are wired up with the D-Pillar speakers to the RSA and then the radio.
Since you can hear some of those speakers, I suspect either a worn out speaker or a wiring issue.
Eddiec32
