08 intermittent door speakers
stangcrazy84
As stated 08 lt2 I believe every option except navigation and DVD factory everything speakers head unit no Amp just factory as produced
To no rhyme or reason just door speakers will quit like Copperfield boom gone dust in the wind and then random as it went it returns it can be at idol running parked up hill down hill across no reasons just in and out
I'm leaning on the HU but a lil guidance would be helpful
Have you done anything to the stock audio system (doesn't sound like it, but want to be sure)? Have you done any work under the dash in an area close to the head unit, where you might have inadvertently moved or disturbed a connector on the head unit? Are all of the door speakers cutting out at the same time, or is it only 1 door involved?
S
stangcrazy84
Never been inside the dash at all I have owned it for about 10 years and it's done it since the day I bought it
And yes it's all 4 doors at once
Thank you
Shimmy23
WA
first check your fuse panel under the hood. there's a key in there so find the amp fuse and check that first. If its fine, move to the connections/plugs on the speakers. wiggle the wires on each speaker. let us know what you find out.
S
stangcrazy84
Will do but I don't think it came with a factory Amp?
Sabrinaklane
